Umbau Abwasserventil auf elektr. Betätigung
You are right, I forgot to mention that I use an iPhone, but the idea still works with other similar devices and brands which have android app.
This one maybe?
Bearbeitet von Laercio
Das sieht aber nicht besonders stabil aus. Der Hebel ist ziemlich groß, das wird sich wohl früher oder später lockern. Vielleicht sollte da doch noch eine Schelle dran.
Been using since October 2020, is the same size as the oem VW, the first longer part actually is not needed and I don’t know why the person at the store recommend me, I thought about to removing this part so it would be shorter.
You're right and there is another one from Gardena. I think I will have a look on that one. Thank's for the tip.
This one:
Bearbeitet von Ernesto
I see some advantages of this solution:
first is: no cabeling neccessary
second: there is no metall (brass) which will corrode with some salt in wintertime on the streets.
@Laercio: can you monitor the status of the battery in the App?
that would be very helpfull
regards
Günter
Hi Günter,
Yes you can see from the app and can turn on/off from the iPhone control center drop down menu, please check the attached pictures, also I will remove this longer part that they recommend me a year ago when I installed thinking that it would be too much pressure to the device when the tank is full but I think is not necessary.
Cheers!
I think this one from Gardena looks even better and sturdy than mine, it has the 1 inch adapter instead the 3/4 one I have, so stronger and faster to discharge.
Moin ✌️
Ich habe mir das Teil von EVE gekauft und wollte mich heute mal mit dem Umbau beschäftigen. Die große Überwurfmutter sitzt bombenfest, mit einer großen Zange wollte ich da noch nicht ran um evtl Schäden zu vermeiden. An welcher Stelle der Verschraubungen lässt sich denn der vorhandene Ablauf am besten und ohne Schaden lösen?
Bei allen Ventilen (Gardena und Eve) steht in der Beschreibung „nicht frostsicher“.  In Portugal sind die Winter ja nicht so schlimm. Aber bei uns, mit Eis und Salz?
Genial wäre dieses Teil von Gardena:
Batterie 9V soll mind. ein Jahr halten.
aus der Anleitung:
bei dem Ventil scheint ein entsprechender Wasserdruck für die Funktionsweise erforderlich zu sein
meint
Günter
@Ernesto:
hast du das Projekt umgesetzt?
mit Gardena?
Günter
Nein, ich habe den Abwassertank isoliert und beheizt, aber das Gardena ist mir zu unsicher in Bezug auf kälteresistenz. Noch öffne ich manuell.
Die Umrüstung des Grauwasser-Ablassventils auf eine elektrische Betätigung stand bei mir auch ganz oben auf der To-Do-Liste. Die werksseitige Lösung ist so ziemlich das Schlechteste was man sich nur ausdenken kann. Im Zweifelsfalls kniet man im Dreck und macht sich auch noch den Ärmel schmutzig.  Das Wiltec Kugelventil hatte ich schon letztes Jahr im Auge. Idealerweise mit Funk-Fernbedienung, die aber seit Monaten nicht lieferbar ist. Daher habe ich das Ventil mit einem normalen Schalter gekauft:
und am Wochenende montiert. Den Schalter habe ich hinter der Klappe der Toilettenkassette angebracht und finde diese Lösung sogar besser als mit Funk-Fernbedienung.
Erforderliche Teile:
- 12V Kugelventil mit Schalter
- Gewindefitting-Reduziernippel 1 1/4'' AG x 1'' AG zum Einschrauben in den Tank
- Innen-/Aussenwinkel 1"
- Teflonband (ich hatte nur Hanf zur Hand)
- selbstgedrucker Halter für den Schalter im Klokasten
Ich hatte keine Kunststoff-Fittinge zur Hand und habe daher Messing genommen. Wenn man noch eine Verschraubung zwischen Tank und Ventil verbaut, dann muss man die Ventil Steuereinheit für das Einschrauben in den Tank abnehmen. Allerdings wir der Hebelarm dann länger.
Kurze Zusammenfassung der wichtigsten Schritte:
- Originalventil demontieren
- Steuereinheit des Kugelventils demontieren (sonst kann man das Ventil nicht in den Tank einschrauben)
- Reduziernippel und Winkel in das Ventil einschrauben und Teflonband oder Hanf zum Abdichten verwenden
- Die vormontierte Einheit in den Tank einschrauben und dabei ebenfalls Teflonband oder Hanf verwenden
- Ventil ausrichten und Steuereinheit auf das Ventil montieren
- Ein Foto der Kabelschuhe mit der Zuordnung machen und den Schalter vom Kabel lösen
- Das Kabel an der Womo-Unterseite bis zur Fahrertür verlegen (idealerweise durch ein dünnes Leerrohr. Hatte ich aber nicht zur Hand)
- Die beiden Verkleidungsteile des Sicherheitsgurtes demontieren (sind nur geklipst)
- Die Polster der Sitzbank entfernen
- Die Abdeckung über der Heizung demontieren
- Die Schiene wo der Tisch eingehakt wird demontieren
- Die Stoffverkleidung über dem Tisch demontieren (ist mit Klett befestigt, vorsichtig an allen vier Seite ziehen)
- Die graue Holzverkleidung etwas abziehen, dann kann man wenn die Kloklappe offen ist eine kleine Öffnung erkennen
- Nun das Kabel vom Unterboden in das Fahrzeug führen und hinter den Verkleidungen verlegen
- Im Klokasten ist ein vertikaler Kabelkanal. Dort das rote und schwarze Kabel anzapfen und so die 12V Versorgung des Ventils herstellen
- Das gedruckte Schaltergehäuse anschrauben oder kleben und die 6 Kabelschuhe des Schalters anschließen
Die Intention war möglichst nicht durch den Unterboden zu bohren und es hat einiges an Zeit gekostet den oben beschriebenen Weg zu finden.
  • Mag ich 8
hat das schon jemand mit dem Gardena-Teil umgesetzt?
ich bin ja nicht so ein Freund von "Metallen" im Bereich des Unterbodens: Salz plus Feuchtigkeit im Winter sind da eher kontraproduktiv!
Das Produkt von Gardena, wäre derzeit mein Favorit! Es sei denn, dass hier negative Erfahrungen geteilt werden.
Danke an alle Mitwirkenden
Günter
das glaube ich nicht.
ich hab selbst die Gardena Beregnungsanlage und behaupte, dass das Ventil nicht den Druck braucht, sondern ausreichend Druck da sein muss, um die Düsen aus den Rasen zu haben. Bei drei geöffneten Ventilen herrscht halt nur 33% Druck…
Hey in die Runde,
ich muss an der Stelle mal leider von allen Alternativen ala Gardena und Eve abraten. Eve und Gardena vedienen sich ja einen 3/4 Zoll Gewinde und sind innen sogar noch enger. Ich habe seit drei Wochen das Eve dran und bei mir tröpfelt es beim Öffnen nur noch raus. Haare etc. scheinen sich zu sammeln und versperren den Abfluss.
man braucht also mehr Querschnitt…
Sportliche Grüße!
  • Von 206 Mitgliedern gesehen
    olisyncro ser_ega Zohan dadoncamillo oli.rs GCBelugaOS deutscherwachtel Siggi Karaia b13r Zweiradfan mischaniker deepdive2000 Holgersson Trigger-tigger Busfahrer03 Matino RoteSocke danielgiese1980 Muckidackel freeeze Roger_G mti_pl Cali-Meer-Ooh gueldner69 Luvpinkler CaliNero slk-A4 Sunsetsandsideroads braegel69 Californiger Lienad JaexMex Norwegenfreund Frankn Eges rage_0815 Mostep prth Vanlife-6a Q-mo Giru Quentin_van_Huissmann WuRie meier72 gc27 califranjo Rene2209 Flh75 PaulW mx2002 klaus007 VWFan ThomasR m.c.krohn Onlyvans Kai184 thnbd Mr.Walkman _FKO AndreGC680 Ekki-Hamburg MarioRS RonnyGC WoMo_Chris andre1601 Mannims65 norrland bustrip Aachengerd bayer1639 chappy Bobby59 LoewsKurve Fvkrogh T4-Diebstahl apfelquark HungrySailfish FrankKipf Obersulm Rockiebal leon-loewe n.t5 JoeFlash Brummdad Kleber DonPellegrino BuDa Semmel200 Brisko Moasta callilui Salmix Gabriel_s Emmental GCharly tonitest CptCaracho Bart7974 Hexemer +106 Mehr
