Umbau (T6.1 California Ocean MJ2021) auf 2*Lithium 105AH (LiFePo4)
themrg
Thanks a lot for the effort!
@Tim_Jochen hmm, I wired the dc/dc charger, completely removed the VW original battery shunts and hooked up the LiFePo4 batteries as well as the starter battery and connected shore power, but can't detect any increased voltage from the charger on any of the fuses (the dcdc doesn't kick in either as incoming voltage is to low).
The CU battery display is reporting 100% charge and reports the voltage from the starter battery (12.7 if I remember correctly while the LiFePo4 is at 13.1). My theory is that as the starter battery is 100% charged thus the CU might not give the charger signal to start, but I don't know.  That leaves me a bit stuck as I can't identify the fuse by measuring the voltage increase over the fuses while on shore power.
Well, I might have to mount everything, drive for a while and then dismount the drivers seat etc. and have a go at it again.
But, do you have any more information that might be useful, if my theory is correct and anything else I could do find the fuse? I have my hands on the circuit drawings from this forum, but unfortunately they don't cover the endpoint of the charger output...
Bearbeitet von jmstockholm
  • Von 145 Mitgliedern gesehen
    werblatt T5Driver99 Emmental Rolltogether Californiger jmstockholm vieuxmotard stw Jspi Tim_Jochen shoulders chillo Sandraeb ppschmitz pku70 wobie danshred CherryBuzz Sofasurfer -michaR- cornzy Zauncamper Filou04 toulouse Unbekannter Tarmac96 jeyniz Afrimi alexo Kombi stag sunshower Holgix classicline2009 motorpsycho Callipeer ISbaer swoosh999 CaliOvali Rou.Bah Carli_Greige Guifravo 3883 ToeterNito znake Haens MichaelS dergerd Armundbrav Hanuk Bread MAtti_T3 EBST dude2 HaDampf Bastix Lockerhauser CCSM54340 Tiko Attila1907 segli AWAXAR24 silvan_gw EwaldTx Aquarius5801 Oiram23 Tango_0 BulliWolle mimo76 paragliding mobi.pelle g1ocke RudiRabaukeT6 Nachtwaechter Benno_R harti77 dablju mwolfer enibas Kolemuel Gelbetomate Reno66 themrg heiligsblechli surging noclass Pitflit Phoma peso Bulli13067o SirAlex UdbyAutoserviceDK Thomas_Hohenzollern fdoe ErwinR cago_de waldeck1889 sonija Dokkarek yps77 +45 Mehr
