Autarkiepaket (LiFePO4 / Solar) von "Car Electric"
bernhard.steinert
Hi Florian,
Knaus Boxdrive Crafter based campervan, two leasure batteries
We have a Knaus Boxdrive with two leisure batteries (one onder the hood, the other under the bed) each with a battery sensor. I would like to replace these with a single Saftkiste Pro 340 and a Victron Multiplus 1600 inverter (not the 2000) and for the rest the setup that you offer for the grand California.
I am in contact with CamperTrek in Diessen in the Netherlands. They also do not know how hard it would be to get this alternative and more affordable setup to work and hesitate trying as it may cost them more than they would make on installing it.
My understanding is that if VW/Knaus sold vans with 1 or two leisure batteries it ought to be possible to decommission one of these in the software, correct?
If hope you can confirm to me and others that this setup would work and that we can get the software setup to function as it should on a Knaus Boxdrive. It has the same display (supplied bt Dometic) as the previous model used by VW.
At the moment I have two dead leisure batteries and hope to be able to replace it with a single Saftkiste Pro 340, Victron booster, Votronic starer battery charger and the Victron Multipus 1600 inverter (the model you offer for the smaller VW campervans)
Hi bodebo,
Please get in contact with us via email and ask to forward to Florian: vertrieb@batterieschmiede.de
I'm sure we can help you :)
Have a good day!
Ich habe ein Modelljahr 2026, ohne Solar. Das gibt es ja nicht mehr ab Werk. Was für ein Solarpaneel rüstet ihr beim 600 nach? Das abgerundete Klebepaneel vorn in der Schräge wie im Original?
hat schon jemand Erfahrung mit der Saftkiste von Califaktur ?
Die beschreiben den Austasch als Plug&Play, einfach selbst zu machen, mit voller Komartibilität zur VW Elekrtonik und Unbedenklichkeitsbescheinigung von VW.
Hierzu die Frage, besteht die auch, wenn man die Saftkiste selbst einbaut ?
170Ah mit nur einer Batterie, wenn auch teuer, klingt verlockend.
besten Dank,
schönen Sonntag,
willi
Ich glaube dieser Kit ist identisch zur dem von Saftkiste. Sucht dort zu bestellen. Die haben sucht die installierungsanleitung online.
Preislich sind sie aber unterschiedlich?
wie dem auch sei, ich finde es Mega.
Nur für mich zu teuer, auch wenn sie es sicher wert sind …
  • Von 272 Mitgliedern gesehen
    Paulistda Garvin ray.luigi jrohh bodebo Bo1848 Riggert Hexer Cali25 VollgasD RandytheBrain Horst_Beach KaptnJoe Mojo MFBS Michi2 abgeordneter Floo Grisou i319 a_tatscho exCEer haaner Baci Hartigan Bulliro SaftkistePRO_Florian Callimania 2bas Tarmac96 Pitflit Chanel CaliOvali Multicali ritschus hansi999 tobylax ciburidelacantonada Bartleby Phili39 starwars ErwinR enigma daefu21 Vespafahrer5 Anti GerriZwei Hpl19 Avante solarsolar Bullimaran Hanuk Johnny_Fly Balou-Sun Majanicho2020 GerSchi willib zpalm Maffy alpenfisch schlossi Pat89 mb0610 Lukasb UnionBus Buggy Fluppi BenBsp gesch Tozi1967 brezli Oceandream Cali_0712 Adddi FmS71 Winki uschi11 california_1991 strojnik1 swoosh999 pao1o califranjo nofraghein schmad Callinichda Tim_Jochen MrHomn mallej ThorstenLu born2rock Fuxxx2 Phil-Cali Unbekannter chruesi stw Californiger gorkal14 Breitler oceanfrank p.eter +172 Mehr
