Autarkiepaket (LiFePO4 / Solar) von "Car Electric"
bernhard.steinert
Hi Florian,
Knaus Boxdrive Crafter based campervan, two leasure batteries
We have a Knaus Boxdrive with two leisure batteries (one onder the hood, the other under the bed) each with a battery sensor. I would like to replace these with a single Saftkiste Pro 340 and a Victron Multiplus 1600 inverter (not the 2000) and for the rest the setup that you offer for the grand California.
I am in contact with CamperTrek in Diessen in the Netherlands. They also do not know how hard it would be to get this alternative and more affordable setup to work and hesitate trying as it may cost them more than they would make on installing it.
My understanding is that if VW/Knaus sold vans with 1 or two leisure batteries it ought to be possible to decommission one of these in the software, correct?
If hope you can confirm to me and others that this setup would work and that we can get the software setup to function as it should on a Knaus Boxdrive. It has the same display (supplied bt Dometic) as the previous model used by VW.
At the moment I have two dead leisure batteries and hope to be able to replace it with a single Saftkiste Pro 340, Victron booster, Votronic starer battery charger and the Victron Multipus 1600 inverter (the model you offer for the smaller VW campervans)
Hi bodebo,
Please get in contact with us via email and ask to forward to Florian: vertrieb@batterieschmiede.de
I'm sure we can help you :)
Have a good day!
Ich habe ein Modelljahr 2026, ohne Solar. Das gibt es ja nicht mehr ab Werk. Was für ein Solarpaneel rüstet ihr beim 600 nach? Das abgerundete Klebepaneel vorn in der Schräge wie im Original?
hat schon jemand Erfahrung mit der Saftkiste von Califaktur ?
Die beschreiben den Austasch als Plug&Play, einfach selbst zu machen, mit voller Komartibilität zur VW Elekrtonik und Unbedenklichkeitsbescheinigung von VW.
Hierzu die Frage, besteht die auch, wenn man die Saftkiste selbst einbaut ?
170Ah mit nur einer Batterie, wenn auch teuer, klingt verlockend.
besten Dank,
schönen Sonntag,
willi
Ich glaube dieser Kit ist identisch zur dem von Saftkiste. Sucht dort zu bestellen. Die haben sucht die installierungsanleitung online.
Preislich sind sie aber unterschiedlich?
wie dem auch sei, ich finde es Mega.
Nur für mich zu teuer, auch wenn sie es sicher wert sind …
es hat alles etwas länger gedauert, aber inzwischen ist die UBB auch für das Facelift Modell (ab MJ 2025) da :)
Du findest die Urkunde auf unserer Produktseite:
gibt es mittlerweile Erfahrungen mit dem AutarkiepaketPRO von Saftkiste?
Jemand mal einen Selbsteinbau gemacht?
Gruß Holger
Auch Moin!
Ich habe zwar die Saftkisten nicht selbst eingebaut aber meine Erfahrungen nach einem dreiviertel Jahr im Einsatz sind sehr gut. Ich hatte kurz überlegt die Saftkisten selbst einzubauen, bin aber in der Elektrik nicht ganz so versiert und habe es vorgezogen einen Saftkisten-Einbaupartner zu beauftragen. Im Frühjahr hatte ich noch die Solarpanels von Califaktur erworben, welche recht einfach einzubauen waren. Die Kombination aus Saftkisten und den Califaktur-Solarpanels funktioniert richtig gut. Ab mittlerem Sonnenschein sind wir für einige Tage autark, nutzen einen Wasserkocher und laden unsere S-Pedelecs am Bus. Und auch wenn die Sonne mal nicht scheint, sind können wir locker mindestens 3-4 Tage autark stehen und nutzen alle Verbraucher inklusive Ladegeräte ohne Einschränkung.
Bearbeitet von jrohh
  • Danke 3
Hi zusammen,
ich habe mal eine Frage an alle stolzen Besitzer des CarElectric Autarkie-Pakets. Ich bin auch einer davon und habe es seit nunmehr ca. 3 Jahre und seit dem Frühling auch noch eine dritte Super B Epsilon 100Ah Batterie unter dem Beifahrersitz.
Zudem noch Solar auf dem Dach und ein Victron MPPT. Für die Kaffeemaschine eine Ecoflow Delta 2 noch zusätzlich zwischen den Sitzen.
Das Setup macht mega Laune und ich erinnere mich nicht mehr, wann ich das letzte Mal das Stromkabel ausgepackt habe.
Eine Sache jedoch geht mir ziemlich auf den Kecks.
Ich bin quasi süchtig danach, vor allem wenn die Sonne scheint, ständig in die Apps zu schauen und zu gucken was reinkommt, welche Batterie wie geladen wird und wie voll sie ist. Das wechseln zwischen den verschiedenen Apps und das Rumklicken in jeder ist meiner Meinung ziemlich mühselig.
Geht es euch auch so?
Da ich etwas im Programmieren bewandert bin, überlege ich, ob ich nicht mal alle wichtigen Werte nicht einfach in einer Dashboard App zusammenbringe, um einfach in der Lage zu sein eine einzige App aufzumachen und dort auf den ersten Blick alles zu sehen.
Wie ist eure Erfahrung mit den Apps?
Da ich neben dem Setup von oben auch noch zwei Thermometer, Starlink und einen Gasfüllstandsensor besitze, würde für mich sowas Sinn machen.
Bin gespannt auf eure Feedbacks.
Für welche Betriebssysteme?
Und auf welcher Programmierbasis (Sprache etc)?
Bearbeitet von tonitest
Hi Paul,
Vermutlich ist es für dich nicht interessant, da du ja schon ein Autarkiepaket hast mit dem du zufrieden bist, aber ziemlich genau was du dir vorstellst kannst du mit dem
umsetzen :)
Mit der SaftkistePRO kannst du diverse Geräte einbinden (u.a. Victron Geräte und Sensoren) und anschließend gesammelt in der App darstellen und per LTE einsehen. Außerdem bekommt man bis zu 680Ah in den Grand Cali oder bis zu 340Ah in die kleinen Californias und noch ein paar weitere Funktionen wie Standort, Wasserwaage etc.
Wenn du Fragen dazu hast nur zu :)
Schönes Wochenende!
Flo
Moin Jörg,
ich dachte an Kotlin um Plattform unabhängig die Codebase zu gestalten. Sprich Ziel sollte schon von Anbeginn sein, die App sowohl auf iOS als auch Android zu bauen.
Moin Flo,
gut zu erfahren! Liest sich sehr gut. Ich bin ein early adopter. Als ich mich damals für das Autarkie-Paket entschieden habe, war Car-Electric, meines Wissens nach, der einzige Anbieter mit einer VW Freigabe. Du hast somit Recht, die Saftkiste Lösung kommt für mich nicht in Frage, sowie für viele andere mittlerweile auch.
Was mich jedoch interessieren würde ist, wie ihr die Daten aus den Steuergeräten ausliest, wenn die Zündung aus ist.  Habt ihr da irgendeinen Bypass an den Steuergeräten zwischengeschaltet oder sendet ihr Wake-Ups über das Gateway um die entsprechenden Steuergeräte aufzuwecken, um im Anschluss die Daten abzufragen?
  • Von 157 Mitgliedern gesehen
    Schumi84 PaulVanCali Knille707 brezli HawaiiHai JanKorsika Hans_87 jrohh FreeDriver Paulaner Gasper Jspi MichaWM Callinichda Semmel200 AP2020 GECO Frank54 msk Habi29312 Bulli13067o Mainline GerriZwei Emmental swoosh999 Himar aderci haaner radrenner chillo Rolltogether BePla Hartigan tonitest derDicke pao1o CherryBuzz JojoChester voelligahnungslos oceanfrank Holgi993 Carli_Greige Nero3 SaftkistePRO_Florian PaulW Californiger Oelfuss Zopfffff Haens Numinis ommelt MBüscher Schuli classicline2009 hans_771 patseeu noahgautschi heiligsblechli abbovm Hein enigma chruesi Adddi wobie stw Hans1 Kralle BubuCali Buny AARR aushilfsheld surging minimad13 KaptnJoe DaDexta1985 LaserLord heggerichs BulliSuse Enjoy Bullitt-2.0 talonmies life_is_a_beach SpiffX ruedigerZ AloisGreiner Micha18 FX93 BjoernC MatthiasBeach79 mramm Rene55 wiwido01 Medly Baschtl FKB_cali oesi2 Jo1970 kawaursus deepdive2000 Rolipoli +57 Mehr
