Autarkiepaket (LiFePO4 / Solar) von "Car Electric"
bernhard.steinert
Hi Florian,
Knaus Boxdrive Crafter based campervan, two leasure batteries
We have a Knaus Boxdrive with two leisure batteries (one onder the hood, the other under the bed) each with a battery sensor. I would like to replace these with a single Saftkiste Pro 340 and a Victron Multiplus 1600 inverter (not the 2000) and for the rest the setup that you offer for the grand California.
I am in contact with CamperTrek in Diessen in the Netherlands. They also do not know how hard it would be to get this alternative and more affordable setup to work and hesitate trying as it may cost them more than they would make on installing it.
My understanding is that if VW/Knaus sold vans with 1 or two leisure batteries it ought to be possible to decommission one of these in the software, correct?
If hope you can confirm to me and others that this setup would work and that we can get the software setup to function as it should on a Knaus Boxdrive. It has the same display (supplied bt Dometic) as the previous model used by VW.
At the moment I have two dead leisure batteries and hope to be able to replace it with a single Saftkiste Pro 340, Victron booster, Votronic starer battery charger and the Victron Multipus 1600 inverter (the model you offer for the smaller VW campervans)
Hi bodebo,
Please get in contact with us via email and ask to forward to Florian: vertrieb@batterieschmiede.de
I'm sure we can help you :)
Have a good day!
Ich habe ein Modelljahr 2026, ohne Solar. Das gibt es ja nicht mehr ab Werk. Was für ein Solarpaneel rüstet ihr beim 600 nach? Das abgerundete Klebepaneel vorn in der Schräge wie im Original?
hat schon jemand Erfahrung mit der Saftkiste von Califaktur ?
Die beschreiben den Austasch als Plug&Play, einfach selbst zu machen, mit voller Komartibilität zur VW Elekrtonik und Unbedenklichkeitsbescheinigung von VW.
Hierzu die Frage, besteht die auch, wenn man die Saftkiste selbst einbaut ?
170Ah mit nur einer Batterie, wenn auch teuer, klingt verlockend.
besten Dank,
schönen Sonntag,
willi
Ich glaube dieser Kit ist identisch zur dem von Saftkiste. Sucht dort zu bestellen. Die haben sucht die installierungsanleitung online.
  • Von 233 Mitgliedern gesehen
    a_tatscho Zauncamper nick0297jan Rolltogether Almroad hans_771 aderci DaDexta1985 bodebo vieuxmotard tonitest abgeordneter radlrob Semmel200 Gasper Emmental p.eter Adddi zpalm willib Tarmac96 Arkon Grunemer calicamper69 StefanM Tim_Jochen BePo tompe01 MalteL wooris Schattenpark3r shoulders Sigerik mb0610 gorkal14 Unbekannter exCEer Franz56 ThorstenLu CaliOvali Pascal991 happymac oceanfrank SaftkistePRO_Florian Lukasb demmo swoosh999 haaner Fuxxx2 JojoChester T2-Fahrer CherryBuzz JoeFlash MrHomn radrenner heiligsblechli Californiger pao1o born2rock MarioRS Filou04 FrankB Palmer01 Go321 Carli_Greige Paulaner stonie Famous13 Andy2505 Schimmic sunshower thomasvo RoLee idontunderstand Avante MUC_Cali patseeu Thosch JanKorsika wobie pseudonym bonanzarad HerzogJan Golfred Multicali Schuli Nero3 KaptnJoe derDicke california_1991 RayP Aurora2023 voelligahnungslos magicrunman Sandraeb Mainline AP2020 -michaR- Nickman_83 Segelsonne +133 Mehr
