Re-engineering the Grand California 680 – from OEM compromise to a coherent, integrated system
Bizzaru
Hi everyone,
This story started in August 2024, when I bought a VW Grand California 680. During the first months (summer / early autumn) I enjoyed the van exactly as it came from the factory. Pretty quickly, however, the real limitations of the OEM setup became obvious.
Why I decided to take it apart completely
– OEM battery: real off-grid autonomy of 24 hours, after which the fridge went into protection
– weak shower pressure once the battery dropped
– toilet emptying: inconvenient and unpleasant chemical smell
– winter use: significant temperature difference between front and rear
– road noise: furniture and fittings → about 40% of driving fatigue
In short: it worked, but not as a coherent system.
Concept & approach
The decision was to rebuild the van as a system, not as a list of accessories.
Advantages:
  • own workshop hall
  • direct access to CNC machining, 3D printing and custom furniture
  • 2–3 professionals involved throughout the project (electrical, mechanical, furniture)
The van was fully stripped: from the toilet area to the rear doors.
On one side, only the kitchen unit remained.
Insulation & structure
The OEM insulation was honestly very poor.
There were areas with no insulation at all.
I rebuilt the insulation completely:
  • walls
  • doors
  • cold zones in the rear
The temperature difference between front and rear is now almost gone.
Electrical system – EcoFlow Power Kit
– EcoFlow Power Kit 5 kVA
– 3 batteries (one optional battery in the former gas compartment)
– battery placement designed to balance vehicle weight relative to the fresh-water tank
– dedicated fresh-air intake for EcoFlow (not recirculated warm air)
Current charging:
OEM alternator: ~1.2–1.6 kW
Planned upgrade:
secondary alternator → 6 kW continuous charging
Control & KFG integration
I developed a custom communication module for KFG, OEM-fit, which:
  • switches interior and exterior lights
  • controls the water pump
  • controls the awning
  • integrates additional functions without errors in the OEM system
For KFG, everything behaves like factory hardware.
Water system
– upgraded water pump
– grey-water tank:
  • insulated
  • heating pad
  • mechanically protected
– electric drain valve, controlled from the dashboard
– dedicated camera to see exactly where the tank is being emptied
Toilet
– Clesana C1
– complete elimination of chemicals and smells
– clean integration, no space compromises
Heating & air distribution
– redesigned hot-air ducting
– proper heat distribution to the rear
– front and rear comfort now match
Audio & noise reduction
– sound insulation: front doors, sliding door, rear doors
– true 3-way audio system, enclosures calculated to manufacturer specs
– dedicated amplifier + DSP
– subwoofer with independent control
– major improvement in driving comfort
Lighting
– OEM LED strip replaced with a digital LED strip
– ON/OFF via OEM display
– colors and scenes controlled via my own app
Connectivity
– 5G modem, easily accessible
– Starlink for areas without mobile coverage
– stable connectivity for remote work
Cameras & exterior
– 1080p rear camera, OEM-fit for the large display
Awning & step
– longer awning, extending past the rear window
– electric operation + app control
– new step with a control module that perfectly simulates the OEM step for KFG
General principle
I avoided drilling the van wherever possible. Where drilling was unavoidable:
  • custom ABS parts, OEM-fit
  • body protection
  • VW-recommended sealant
What’s next
  1. secondary alternator (6 kW)
  2. rear furniture reconfiguration:
  • daytime: sofa / lounge area / nighttime: full bed, no compromise on sleep quality (same or better than the current setup)
Questions, criticism and ideas are welcome.
Because of forum limitations, I can’t include everything in a single post (photos).
I will therefore add separate follow-up posts, each with photos that relate to the topic.
  • Mag ich 3
  • Danke 2
OEM insulation:
Rebuild insulation:
All the walls doors and roof top have been reinsulated.
Photos & gallery note
Uploading photos directly to the forum is quite slow and limited, so I will create a OneDrive photo gallery where I’ll upload all relevant pictures in full resolution.
  • Danke 2
Servus Bizzaru,
very impressive, thank you for sharing!
Do you offer such a reconstruction, or partly optimisations, professinally or is this a solely private improvement project?
Greetings from Vienna, Mario
Hi Mario,
thank you very much for the kind words, I really appreciate it.
At the moment this started as a private project, driven mainly by passion and curiosity rather than a predefined commercial offer. That said, I don’t exclude the possibility of offering selected optimizations or reconstruction work in the future.
For now, I’d prefer to first finish documenting the project here. After that, I’d be very interested to hear what you liked most and what kind of changes or optimizations you would personally be interested in. That feedback will help me understand where this could make sense beyond my own van.
Greetings to Brasov,
Bizzaru
This custom control unit is the central interface between the OEM KFG system and the additional functions added to the van.
Through this unit I intercept and manage signals from:
  • physical switches
  • vehicle ignition / contact
  • exterior LED strip
  • bathroom light
  • exterior lights
  • interior digital RGB LED strip
The unit also includes a Bluetooth application, which allows additional control and configuration without relying on the OEM display.
One important feature is that the audio system can be powered on and used without ignition. This makes it possible to use the full Hi-Fi system while camping or parked, without turning the vehicle on.
The goal was seamless integration:
  • OEM behavior preserved
  • no KFG errors
  • no visible “aftermarket logic” from the driver’s perspective
From the outside, everything behaves like factory equipment, while internally the logic is fully customized.
Lighting
For the exterior lighting I wanted a clean installation and correct light direction, not just “mounted lights”.
The body shape was 3D scanned, and based on that I designed and 3D printed custom adapters that match the curvature of the vehicle perfectly.
These adapters create a flat mounting surface, allowing the lights to be installed at the correct angle.
As a result, when the lights are switched on, the beam is directed exactly toward the ground, where it’s actually needed, without glare or wasted light.
This also allowed me to avoid unnecessary drilling and keep the installation visually and technically OEM-like.
  • Von 120 Mitgliedern gesehen
    CaliNero ger1028 Bizzaru NicoGiese _FKO CptCaracho aderci Tivan56 Mainline bpunktm Berfuc marchugo Moasta Ranger nick0297jan Oberbayer AndreGC680 T2-Fahrer JohnCoop Go321 Slowmover motorpsycho n.t5 stonie Flanders Unbekannter D.Fleischer Muckidackel danshred Haikumsai Sillo DonPellegrino Bart7974 JPFFN vieuxmotard BePla Kleber Obersulm callilui Emmental MarkusLo Felone GCharly califranjo chruesi exCEer radrenner Bo1848 sten208 Richih FrankKipf ortho4 idid Lienad Winter2004 Antheo ufo61 Brisko mrsticks Breitler nordish82 hans_771 ToG1410 Calinoob kayuwe Semmel200 BuDa GruenNdB Globe alke Maffy calimerlin Daik wawro Xenia Mannims65 Der_Billa Californiger MarioRS 3pax Salmix haaner Hexemer Alex17 apfelquark Obsidian chappy JoFe MrHomn Basti19 Schmack prth Rockiebal GC-Freund JTT Mifoss20 Hasenjaeger Silvie4444 mrx radlrob +20 Mehr
