Re-engineering the Grand California 680 – from OEM compromise to a coherent, integrated system
Hi everyone,
This story started in August 2024, when I bought a VW Grand California 680. During the first months (summer / early autumn) I enjoyed the van exactly as it came from the factory. Pretty quickly, however, the real limitations of the OEM setup became obvious.
Why I decided to take it apart completely
– OEM battery: real off-grid autonomy of 24 hours, after which the fridge went into protection
– weak shower pressure once the battery dropped
– toilet emptying: inconvenient and unpleasant chemical smell
– winter use: significant temperature difference between front and rear
– road noise: furniture and fittings → about 40% of driving fatigue
In short: it worked, but not as a coherent system.
Concept & approach
The decision was to rebuild the van as a system, not as a list of accessories.
Advantages:
  • own workshop hall
  • direct access to CNC machining, 3D printing and custom furniture
  • 2–3 professionals involved throughout the project (electrical, mechanical, furniture)
The van was fully stripped: from the toilet area to the rear doors.
On one side, only the kitchen unit remained.
Insulation & structure
The OEM insulation was honestly very poor.
There were areas with no insulation at all.
I rebuilt the insulation completely:
  • walls
  • doors
  • cold zones in the rear
The temperature difference between front and rear is now almost gone.
Electrical system – EcoFlow Power Kit
– EcoFlow Power Kit 5 kVA
– 3 batteries (one optional battery in the former gas compartment)
– battery placement designed to balance vehicle weight relative to the fresh-water tank
– dedicated fresh-air intake for EcoFlow (not recirculated warm air)
Current charging:
OEM alternator: ~1.2–1.6 kW
Planned upgrade:
secondary alternator → 6 kW continuous charging
Control & KFG integration
I developed a custom communication module for KFG, OEM-fit, which:
  • switches interior and exterior lights
  • controls the water pump
  • controls the awning
  • integrates additional functions without errors in the OEM system
For KFG, everything behaves like factory hardware.
Water system
– upgraded water pump
– grey-water tank:
  • insulated
  • heating pad
  • mechanically protected
– electric drain valve, controlled from the dashboard
– dedicated camera to see exactly where the tank is being emptied
Toilet
– Clesana C1
– complete elimination of chemicals and smells
– clean integration, no space compromises
Heating & air distribution
– redesigned hot-air ducting
– proper heat distribution to the rear
– front and rear comfort now match
Audio & noise reduction
– sound insulation: front doors, sliding door, rear doors
– true 3-way audio system, enclosures calculated to manufacturer specs
– dedicated amplifier + DSP
– subwoofer with independent control
– major improvement in driving comfort
Lighting
– OEM LED strip replaced with a digital LED strip
– ON/OFF via OEM display
– colors and scenes controlled via my own app
Connectivity
– 5G modem, easily accessible
– Starlink for areas without mobile coverage
– stable connectivity for remote work
Cameras & exterior
– 1080p rear camera, OEM-fit for the large display
Awning & step
– longer awning, extending past the rear window
– electric operation + app control
– new step with a control module that perfectly simulates the OEM step for KFG
General principle
I avoided drilling the van wherever possible. Where drilling was unavoidable:
  • custom ABS parts, OEM-fit
  • body protection
  • VW-recommended sealant
What’s next
  1. secondary alternator (6 kW)
  2. rear furniture reconfiguration:
  • daytime: sofa / lounge area / nighttime: full bed, no compromise on sleep quality (same or better than the current setup)
Questions, criticism and ideas are welcome.
Because of forum limitations, I can’t include everything in a single post (photos).
I will therefore add separate follow-up posts, each with photos that relate to the topic.
  • Antworten 3
  • Bizzaru
OEM insulation:
Rebuild insulation:
All the walls doors and roof top have been reinsulated.
Photos & gallery note
Uploading photos directly to the forum is quite slow and limited, so I will create a OneDrive photo gallery where I’ll upload all relevant pictures in full resolution.
  • Von 39 Mitgliedern gesehen
    Oberbayer nordish82 mrx radlrob Volker801 ich10 Moasta alke Segelsonne Bart7974 GregorK Oelfuss sepp_sz bpunktm D.Fleischer Onlyvans WuRie stonie Benno_R Fourmotion T.Christoph Mkroenicke callilui Mitmog Felone hanseatic tonitest Bizzaru GCharly Mainline n.t5 FlyingT Kleber CherryBuzz sten208 patseeu GrandCali_600 chruesi Jspi
