Digitales Cockpit nachrüsten
vorrnach
Das normal das der Tacho bis 260 geht? 😅 oder liegt das jetzt an dem Design was du gewählt hast?
Hallo Volker,
gibt es die Möglichkeit, dass die km/h Anzeige reduziert wird? Also zum Beispiel bei 160 km/h Ende ist und dann das ganze Band etwas optisch entzerrt wird?
Danke Dir
André
Vielen Dank für die Bilder, könnte mir schon vorstellen, dass es  auch ein Option für mich ist, es gefällt mir gut.
a video how to remove the existing instrument cluster
and probably like this how to add the electronic board to new instrument cluster
and this instrument cluster theme seems to be till 200km/h
but the revs don't match .... (is like gas car)
Bearbeitet von Silviu
That`s not the case! Please consider the units. The 200 in your video is mph, equal to 320 km/h which is the other value you can switch on.
My mistake .... i did not pay attention to units (the guy is from UK and obvious is in mph)
Did you notice any lag on revs (on the instrument cluster) since you install it?
Is the screen boot up fast enough when you open the door and enter the car ? or just when you insert the key?
Did you by chance scan the car for errors to see if are any on the control module dashboard 17 ( if uses the original board shouldn't t be any error i think)
Thanks
Silviu
No, the RPM gauge responds very quickly—probably even faster than the mechanical stepper motor.
The tachometer starts up as soon as the door opens. I'd guess that takes no longer than 2 seconds.
There are no error messages. After all, the original circuit board is still being used.
Thanks
I am looking for this upgrade for a while and I am now 99% convinced.
One more question: During the day is the screen visible enough when the outside light hit the screen? (when the sun rays hit the screen probably even the original screen is not bright enough so that is the worst case and is temporary)
Thanks again
  • Von 128 Mitgliedern gesehen
    zyklotrop Moasta sonnyboy Silviu Luomen Volkerw1 Dexter aderci tonitest VWFan Haikumsai Kleber Emmental Quentin_van_Huissmann baumi radrenner callilui MaLachML T2-Fahrer gosswald speedcow Bobby59 GCharly ThomasR AndreGC680 Mifoss20 Brummdad DerBussfahrer Manni Californiger exCEer rage_0815 llds25 thnbd MarioRS DonPellegrino polt66 Semmel200 Globe Bertram-der-Bulli S8-Stefan 70erMichel knuffle Holgix n.t5 bustrip Shibafan Mannims65 Back_To_Bus Salmix Felone DarkGeneral88 Yellowspider silversurf malle Rockiebal reiseduo Rene2209 Flanders D.Fleischer Calli T5 Hein leon-loewe Suedwind2004 Nero3 Mkroenicke Basti19 Volker801 chruesi Brisko califranjo FrankB ASI haaner Fram Vicot Mario82 mrsticks wobie Ranger pommes101 Benno_R nick0297jan Habi29312 GruenNdB Sven2503 Schmack FrankScherer obervolta Obersulm Kai184 Chu600 CptCaracho MichaWM Slowmover Daik T4-Diebstahl Sandraeb PatrykTlatlik Bart7974 +28 Mehr
