Breeze Geschrieben 14. Oktober 2020 Teilen Geschrieben 14. Oktober 2020 Hi has anyone chosen this option and is it working well? Regards, Will Zitieren Link zu diesem Kommentar
Mat5 Geschrieben 14. Oktober 2020 Teilen Geschrieben 14. Oktober 2020 Yes, I did Yes, it is working well Yes, it is shown in the display nicely but for what reason .... Yes, its expensive It has an internal WIFI antenna, good for outdoor surfing .... I dont know if there is any external antenna connected I would not order this option again, it´s fun, it´s tech but a normal personal hot spot by phone works the same Zitieren Link zu diesem Kommentar
Breeze Geschrieben 14. Oktober 2020 Autor Teilen Geschrieben 14. Oktober 2020 Hi Mat, Many thanks for your reply. I have this option (lesswire) but believe I have an problem as I have little signal unless I am camped close to a Vodafone antenna. I carried out a speed test when I do have a signal. When connected via WiFi I had 2.4 Mbps download, a then connected via 4G I had 18.9 Mbps. this indicated to me that there is an issue either with the antenna or the router itself. If you have an opinion please share as I would appreciate it. Regards, Will Zitieren Link zu diesem Kommentar
