WiFi Antenna Location
Breeze
Hi all,
Does anyone know the location of the WiFi antenna, (GC 600) is it the roof arial ?
Thanks in anticipation
  • Antworten 4
  • Breeze
  • n.t5
Aktive Tage
Hi Will,
the original WiFi antenna is mounted just over the sliding door.
Regards Norman
Hi Norman,
many thanks for your advice, can you see it? Is it visible. I only ask as the reception is very poor
thanks again
No, you don't can see them. The antenna is located behind the side panels above the sliding door.
Surly this will interfere with the signal, does yours work well, mine does not. I did a test
1. Wifi Connected via on board router download 1.8 Mbps
2 4G via iphone - Vodafone 23.4 Mbps
Any ideas Please,
Will
    deepdive2000
