VW LTE Router Issues
Breeze
Hi all,
I have this option installed and to-date it has not worked very well at all, The LTE router is manufactured via Lesswire GmbH.
In the UK it is sited under the drivers seat, however unless I am camped close to a phone mast it will not connect. I believe that that the antennae is above the side sliding door, however upon inspection only one antenna connection is fitted via VW, Lesswire ask for X2. the antenna connection sockets are mauve in colour.
I am not sure that the actual antenna is located in the best position.
Could anyone who has one fitted confirm how many antenna connection wires you have fitted.
I have spoken to Lesswire via email and found them very helpful and with a great product when installed correctly.
Will
Bearbeitet von Breeze
I have the CCU4 model from Lesswire, where in theory, two antennas can be used. But also in my GC600, only one is used. I didn't follow the cord to see where it ends.   That's bad from VW if Lesswire recommends two antennas.
I am also having connectivity issues, but on another level; I don't see the "Volkswagen" SSID on my devices.
If I type in the SSID manually (which is found on the keycard), it states it cannot be found.
I do see a green led on the Lesswire device (if I activate Wifi on the control panel)
Is the SSID normally hidden?  Or does it only appear when I plugin a SIM card?   I first want to take a look at the configuration settings before I plugin a SIM card.
Only with a SIM-Card inside the WLAN will be activated
best regards
Lutz
Simply just swoop the cable to the far left hand connection. It works.
Hello,
I thought about retrofitting the LTE router and researched everything! According to the VW ETKA catalog, the LTE antennas should be behind the windscreen next to the sensors and should not be available as standard, and must also be retrofitted!
Hi there, the antenna is fitted above the sliding door behind the white paneling and VW only fit x1 antenna. The Lesswire WiFi unit is located under the driver seat UK side.
Ok, driver's silk is on the passenger side in DE.
I look the days to see if I can find LTE cables. The cable construction should be the same for all, or there should only be one.
If you have both antenna cables in place, how about another antenna?
One antenna, does it have one or two connections?
Hi yes it has X2 connections, go to the Lesswire site and download the instructions
Hallo Zusammen,
vielleicht es es ja für jemanden interessant, Lesswire WI4U Pro für 399€, zum nachrüsten!
Hallo Zusammen,
ich habe mir die LTE-Router gesorgt, super Teil!!! Im Zusammenspiel mit einer LTE GPS Antenne kann man sich die Position (Diebstahlsschutz) senden lassen und sogar eigene Website ablegen. WLAN und LTE Empfangsleistung sind gut und er ist sehr schnell
MFG
jwinkler
Ich musste heute einmal den ab Werk verbauten Router ausbauen. Zur Dokumentation der Anschlüsse ein Bild:
Format der SIM Karte ist Mini-SIM. Orientierung der Kerbe an der Ecke links hinten. Die Karte rastet beim hineindrücken ein.
Super, danke!
Ich habe mir eine zweite Antenne besorgt (mit GPS) wichtig dabei ist das die beiden LTE Antennen einen 90 Grad Winkel zu einander haben, dann besteht die Möglichkeit der doppelten Empfangsgeschwindigkeit. Mit der GPS Antenne kann der Router die Postion senden!!
Vielen Dank! Kannst du zur 2ten Antenne eine Bezugsadresse nennen? Installiere ich sofort :)
  • Von 9 Mitgliedern gesehen
    MD_998 Elmex09 philippbr01 Hopserl1 LemmyIan Manni-SAD Patrick67 apfelquark chavalaloco
