Underride aluminium protection for engine, gearbox, differential
ciki62
Hi, I have question, for all of you who raise suspension either Seikel or VB air. Do you also have special aluminium underside protection panels?
Something like this http://www.seikel.de/produkt-kategorie/volkswagen-t6-eh/?lang=eh&filter_produktkategorien=protectors
thanks,.
and sorry for posting in english, you can answer german, i will use google translate :)
p.s.
Kit from Seikel is more than 1200€ for engine and differential. IMHO little bit too much for piece of aluminium.
  • Antworten 3
  • ciki62
  • CaliPilot
  • Knox16
You should take a look at the
The keyword ist ""...
i have the Seikel suspension but just the "widder" protection panel. I thought about the other panels but didn't bought them because i don't have plans to make extreme offroad trips. If you don't abuse your car like a rally race driver you should hear when the engine protector is touching the ground and if so, you shoud turn around ;-)
We made some rough trips through Spain and never had issues, there are a lot of users from this board who made trips through Iceland and even with a 2 wheel drive without protection panels, they all made it well back home...
And yeah, Seikel is pricey, i had the same impression when i looked at their pricelist - 700 bucks for a plate of aluminium. I made then a small company tour with Mr. Seikel and as i saw the panels i was impressed, they are hughe, well welded and fit perfectly under your car. I have never regretted it.
Chris
